Question about The Kitchen Appliances - Others
I have a 2004 Savage Bros. FireMixer-14. All of the sudden the kettle doesn't work. We replaced the fuses and it worked for a minute and then nothing. What do you think is wrong?
  • Drost's Chocolates
    Drost's Chocolates Apr 25, 2019
    Fixed it!! The product temperature was just too low for the kettle temperature when we were cooking it off.
    Top Expert:
  • The Master
  • 63,044 Answers
ELEMENT HAS SHORTED OUT BIN IT AND GET SOMETHING NEW
Posted on Apr 25, 2019
SOURCE:
  • 1118 Answers
SOURCE: Blower stopped working.
Heater blower motor resister is bad, or blower motor its self is bad. Run 12 volts from an outside sourse to blower motor, if it runs its resister if not its blower motor.
Posted on Mar 08, 2009
ftw1952
  • 10319 Answers
SOURCE: 2004 Honda Odyssey -Both power sliding doors suddenly don't work.
have the relay checked out for these doors
Posted on Jul 28, 2010
SOURCE: I have Morphy Richards pyramid kettle. When i
try opening the plug.
Posted on Jul 11, 2011
SOURCE: kettle does not heat up
Just had the same problem. One of the thermostats is probably bad. In my case I replaced both and the heating elements because it was more cost effective. Aside from the drive motor not much else can go wrong. In my case it was worth the $200.00 to replace these items instead of $825.00 for a new kettle.
Posted on Oct 04, 2012
kwhisler
SOURCE: Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Posted on Mar 15, 2015
2004 Suzuki Savage 650 will not turn over
Hi, Phillip before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
SuzukiSavage com 1986 Savage won crank over
why doesn my motorcycle power on
Suzuki LS650 Savage Service Repair Maintenance
https://www.partsfish.com/page/oem-parts-for-suzuki
http://www.savageriders.com/verslagen/transfer/2002_LS650P_Owners_Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 18, 2018 | 2004 Suzuki Savage 650
My kettle is all other sudden not heating up water
Sounds like the heating element has burned out or is shorted, they don't repair this type of appliance they just replace it.
Oct 14, 2016 | Cuisinart CPK17 Electric Kettle
My Hamilton beach 40996 kettle Suddenly it stopped boiling. The on button lights up and reads temp but never boils. It worked and then suddenly stopped. Any chance this is a program problem somehow?
What a crazy over-complicated kettle!
Disc element kettles do tend to have a limited life that is a small fraction of the lifespan of standard kettle elements. The ones I have had usually only last until the guarantee has expired. To discover whether it is the kettle or the base it will be necessary to use a multimeter to check the supply from the base.
Nov 17, 2015 | Hamilton Beach Kitchen Appliances - Others
Suzuki starts when cold and dies when warm, will not even turn over when warm, 2005 650 savage
Sounds like vaporlock. Try insulating the fuel line, especially around hot engine parts.
May 06, 2014 | 2004 Suzuki Savage 650
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
All interior dome light are out on 2004 quest, fuse checked are good
The interior light are controlled by the Body Control Module (BCM).
Check the fuse for the BCM. If the fuse is OK, then try to disconnect the car battery for about 10 minutes to reset the BCM. If resetting the BCM doesn't work you may have to replaced it.
Jun 23, 2011 | 2004 Nissan Quest
Re: Microwave Mod. # NN-H764BF SN: 6A44150194 Manufactured: April 2004 Problem: Was working one minute then al of a sudden 'NO Power', nothing in the digital display.
Did you check fuse. That was the problem I had and I just replaced the fuse and it worked fine. You have to take off the cover.
Apr 04, 2011 | Ovens
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
vince
Kitman
Level 1 Expert
Carlos Alvarez
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
