SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
