I also replaced to starter solenoid, still nothing. the emm lights up but the sensor light goes out. im not even getting a sound from the electric fuel pump when i turn the key. any ideas what can be the problem?
SOURCE: 2001 Taurus just died on road
Under the radiator cover there is a box with a rectangular plug. This is the constant control relay module (CCRM). Replace this part. It's available at the dealer. This controls the power to the ignition and fuel systems. Why Ford installed this electrical component above the radiator is still a mystery to me.
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: entire 1996 blazer electrical dies when starter solenoid engaged
bad ground cable,use a jumper cable from negative to alternator bracket, if it starts thats it.
SOURCE: no power to starter 2004 chevy tahoe
Hi
It could be your neutral safety switch. It could be the starter relay which is located in the fuse panel box. It could be the smaller wire going to the starter could be loose or corroded.
