Washing Machines Logo
Kate Pasola Posted on Apr 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speed Queen Washer agitates and cycles appropriately but does not spin fast enough to properly get the water out of the clothes.
I can wring water out of clothes after the spin cycle is over. It is not overloaded, the worn belt was replaced, and the pump works like a CHAMP. Top loader AWN412
S. hermann
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 30, 2022
S. hermann
Contributor
Level 1:
Answers
Questions
0
Helped
416
Points
Speed Queen RPMs are low! 710 + - is half of what it should be. This is per their own specs.
David Spradling
Level 3:
Top Expert:
  • Speed Queen Master 13,524 Answers
  • Posted on Dec 14, 2020
David Spradling
Speed Queen Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929337
Points
28396
If belt tension ok check under agitator for bad cogs or splines to tub
Level 3:
  • Speed Queen Master 19,187 Answers
  • Posted on Sep 16, 2020
Speed Queen Master
Level 3:
Answers
19187
Questions
0
Helped
4345346
Points
82261
I hope that you ordered the correct part, Also there is an idler pulley that maintains the belt tension and that needs to be checked for proper tension.
5 Related Answers
A
Anonymous
  • Posted on Mar 14, 2007
SOURCE: can't get washer to finish spin cycle
I have the same problem they can not fix it so dont waste your money on a repair guy they just run it through a dianostic test and tell you that you are no using the machine properly
Anonymous
  • 183 Answers
  • Posted on Jul 30, 2007
SOURCE: Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Anonymous
  • 156 Answers
  • Posted on Feb 25, 2008
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Anonymous
  • 68 Answers
  • Posted on Jan 17, 2009
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Anonymous
  • 7 Answers
  • Posted on May 05, 2009
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Spin is not going fast enough to dry out clothes
spin is not suppose to dry the clothes, simply wring the most water it can from them.
are you sure you are not set on a gentle cycle? might your washer offer a extra spin cycle?
When in spin cycle does not drain all the water we have to hand wring all clothes
if all of the water does not drain could be the water pump or if the washer does not spin fast enough to wring the clothes could be a worn out motor or tansmission
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
1helpful
2answers
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
