SOURCE: Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
SOURCE: kenmore 12502100 white plastic dusty residue
Sounds like washer mites. Put some cheese on the top of the washer after the load finishes. Then leave for at least 60 minutes. The mites will eat the cheese, be satisfied, and your wash will be good next time.
SOURCE: gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
