SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
please RUN the software calibration and fix it The Steps for Newer Style
Console Calibration 1.
Locate the calibration area on
the rear or underside of the console (a hole, near the console's center, that
goes through to the electronics board. (This hole should not have a
screw in it.) 2.
Insert a pencil (eraser
end), into the hole and feel around for the cal button (will click when
pressed). 3.
Press the button 2
times (with the pencil eraser). The first click should show CL11 in
the console, the second click should show CL21. 4.
If the process was done
correctly, and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons on
the console and observing settings. This will not require any other tools. 5.
Press ENTER. CL22 should
display in the TIME window and (??) in the SPEED window. 6.
Press ENTER. CL23 should
display in the TIME window and (??) in the SPEED window. 7.
Press ENTER. CL24 should
display in the TIME window and (??) in the SPEED window. 8.
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window. 9.
Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E." 10.
Press ENTER. You should see
"SS" or "55" in the console. 11. Push the STOP/START button. For safety, at
this point, you should step off, or be off, the treadmill. 12.
Push the ENTER button. The
walking belt should start to move, accelerate to maximum speed, then stop on
its own. 13.
When the belt stops, the
incline should self test by raising to its highest incline
position, then lowering back down to its lowest position. 14.
Once the incline test is
complete, push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use. 15.
If the letter "F"
appears in the SPEED or INCLINE window when the power button is pressed 2
times, the treadmill is indicating a failure somewhere either in the
SPEED or INCLINE (depending on the window the "F" appeared in).
Troubleshooting the failure would be the next step.
.God bless you
Console Calibration
1.
screw in it.)
2.
pressed).
3.
Press the button 2
4.
5.
6.
7.
8.
9.
"E."
10.
12.
its own.
13.
14.
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
