Question about Golf
Installed new batteries cart runs fine but charger will not start when I plug it in. Took charger to battery dealer he said it is good
SOURCE:
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
SOURCE: 1997 chevy silverado 3500 with
We found the problem by taking the truck to the dealership, after spending $550.00 on parts and having everything we could remove tested or we purchased them new and replaced them. We spent two weeks on it and took it to Chevrolet but it took them three days after all we had done, the problem turned out to be the gear on the distributor, sure we replaced every part in it but because we could not get the distributor out with the intake on it we had not even considered the gear, thanks for your assistance and maybe we'll try you again next time....Thanks again.
Posted on Jan 17, 2009
  • 82 Answers
SOURCE: I have 2004 EZgo electric golf cart. When I plug
Check for a tripped circuit breaker. usally at inline with the positive cale of the battery
Posted on Mar 25, 2010
dttech
  • 4803 Answers
SOURCE: I have a 1984 dodge D150, not charging, battery is
The first thing you need to do is stop wasting your money by replacing parts. Then get a volt-ohm meter and a test light to test the circuits between the battery, the alternator, the ignition switch, the starter relay and the voltage regulator. (a.k.a. Charging System Circuits)
To start, the "B+" or "BATT" terminal on the alternator (large black wire) MUST have a solid, direct connection to the battery. Check for the proper voltage here. Then, the red wire on the alternator at the "F2" terminal should be HOT at all times. If not, you probably still have a bad fuse link that you missed. The "F1" terminal on the alternator (Light Green wire) is known as your "FIELD" wire. It comes from the "IG" terminal at the voltage regulator. It should be hot any time the key is in the ON position. If not, your voltage regulator is not working or your ignition switch is not providing power to the regulator. Finally, The "F" terminal (Red wire) at the regulator should be hot any time the ignition switch is in the ON position. This actually gets it's power from the starter relay, which gets its power from the ignition switch.
Please also review these articles:
What Else Could Be Wrong?
My Car Won't Turn Over
Posted on Jun 12, 2011
SOURCE: My brand new LG Cosmos
I bet you got help and fixed it already, but I had the same problem. Just before it stopped working, I dropped it in a puddle by a curb and I thought that killed it. I didn't realize that my battery was dead! That was it, so charge it!
Posted on Jul 21, 2011
How do you check output voltage from generator to battery in an club car golf cart
if you look at the charger plug there is a small switch it can either be held down with the cover off or with it on. It should read you between 48 and 50 volts DC with that switch in that switch will keep you from charging the batteries if it is faulty. These chargers are really rather simple and golf cart King has the motherboards cheaper than anywhere else that you can buy them. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Oct 31, 2014 | Golf
Why don't I get power to the motor on my Golf cart and how can I fix it.
Pleasecontact golf cart Kings out of Austin Texas. They will be more than glad to help you with this problem that you are encountering. Their Tek savvy is always free. Please be patient as so many people are always asking questions. But you can't beat free. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Aug 21, 2014 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
After installing six new 6V batteries in series on my 1999 Yamaha G16E golf cart, full power is fine up to the selenoid. nopower to the shifter or motor after that. Upon plugging in my charger to the cart,...
Verify series battery wiring. The main positive wire which goes to the solenoid should be on a positive battery post, that will be your main positive. Then from there we go series to all the rest of the batteries until we are left with a negative battery post, that will be your main negative. Make sure your charger wires are connected to the mains.
Sep 11, 2017 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
BuggiesGoneWild has all types of poems. Please visit their website. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
I took my 2009 HD sportster to the HD dealer to get a new tire installed. When I went to pick it up they told me it would not start and that they had charged the battery and installed a new relay and the...
Starter could be jammed have you tried to pop start it? Are you getting power to the starter? Kill switch isnt on is it? Never should have left the dealer it was running when you took it there.
May 14, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
I have recently purchased a G22 Yamaha Golf cart and it's just over 4 years old. The batteries were replaced about 4 months proir to my buying. it goes well but the charger shows after charging a yellow...
When I have this sort of problem, I always double check battery connections, all should be clean and tight and the cables should be in good condition. Then I check each battery under load and see if any voltage drops too much. If that doesn't show any problems then I think a dealer might be your answer. A dealer would have a battery discharge machine that would how good your batteries are.
Jun 15, 2017 | Golf
Can I leave my 2004 ezgo golf cart charger plugged into the golf cart and wall all the time when golf cart not in use?
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Jul 21, 2009 | Electronics - Others
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
