SOURCE: CAN NOT REMOVE THE END
The end caps on the upper rack of my GE dishwasher do not pull off, they "rotate" off by turning the top of the cap toward the center of the dishwasher. In order to make this rotation, you need to slip a small screwdriver in the track to the inside of the nipple at the top of the back of the end cap and force the nipple toward the middle of the dishwasher.
DBK
SOURCE: How to disassemble Maytag Washer MTW5740TQ0
Your console has a retaining clip under the front corner on each side. You simply insert a putty knife under the console at the corner and push straight back, while pushing the console back with your other hand. The clip will release and the console will pop up. You can use the following link for reference (step 2 b.):
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
Your washer has the Maytag name, but is manufactured by Whirlpool and has Whirlpool parts, so these steps are for your washer. The link I provided explains how to access and remove the drive motor. If you are having problems with agitation and spin, you may have bad motor coupling. The next explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The steps are almost identical and the part number (if needed) is included.
You can view an excellent exploded view diagram of your washer at appliancepartspros.com. Section 4 shoes the console and retaining clips (item 3) that I'm talking about.
If your washer fills, then stops, or agitates then stops just before the rinse cycle, this problem is attributed to a lid switch malfunction.
I'm adding all these remarks, because you never stated what symptoms you were experiencing. If you have questions, please let me know. I hope you find this information helpful.
