Question about Health & Beauty
Red light is continuasly flashing red light rascal liteway why
    Top Expert:
  • Health & Beauty Master
  • 29,653 Answers
You will find it is flashing in groups of flashes. Count the pulses and look up the fault code in your user manual.
Posted on Apr 20, 2019
4 Suggested Answers
SOURCE:
adnanbhatti
  • 1188 Answers
SOURCE: when i load the software
As I was previously telling that there are two sub models in this category: S300 and S300M. The 'M' denotes for Mac. If you do not have this model your scanner will not work with Mac even if you install the correct drivers. These scanners do not use TWAIN drivers but use proprietary interface meaning you cannot use other drivers.
But there is a chance you may be able to make it work with Mac. Please let me know the version of your Mac and I'll see if can find some workaround.
Posted on Apr 24, 2010
  • 3247 Answers
SOURCE: Rascal liteway 3 will not
Red light flashing 7 times is likely caused by problem with the speed control dial. Most likely something is wrong with the contacts. This type of problem needs attention by the service centre nominated for Rascal scooters in your area.
Check this site for details.
Hope you are able to get it fixed soon.
Posted on Mar 30, 2011
  • 456 Answers
SOURCE: I have a Liteway Rascal
hi.
as far as i can find out, this is part of the self diagnosing, fault finding system on newer scooters.
different number of flashes signifyiing different faults. i cannot find a specific manual for the rascal scooter, but on most scooters of this type 9 flashes is listed as "other internal fault, return to dealer for inspection"
this could cover absolutely anything. the only thing i can suggest, is that oyu check all of the electrical connections are clean and secure. make sure there is no obvious damage to any wiring, and that all of the control units, motor, and brake unit are clean and secure on the scooter.
there is very little else that a user can do to these scooters, other than returning it to the dealer for a full inspection.
dealers should be able to give you a free estimate of repair costs. and then it is up to you if you have it done or not. the only thing to be careful of, is that most dealers are just interested in selling new scooters, so they will try VERY hard to get you to buy another scooter rather than have your existing one repaired as they can make far more money this way. you will have to stand your ground to get a free estimate.
good luck.
hope this helps
Posted on Jun 22, 2011
I want to download a service manual for a rascal liteway 4 scooter
You may have to order the service manual from Rascal.
Apr 23, 2018 | Health & Beauty
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
Was working ok but washed it now it just flashes a red light 8 times and wont go along
8 flash code is typically a controller fault and there are about 12 sub codes that goes along with that flash code. More than likely you will have to replace the controller.
Sep 05, 2014 | Golden Technologies Liteway 3/4 Wheel...
Rascal turnabout key picture has flashing red light ...scooter wont move
Take a magnet and touch the key symbol on your control.This will unlock it.
Apr 13, 2012 | Amigo Health & Beauty
Lite way rascal 3 red light flashes constantly to indicate sleep mode.I have switched on and off but there is no response.Micro switch ok.Happened before and switching off cured it.also leak on axle which...
According with the manual...
LED Flashes 7 times means a Throttle fault. Engager levers must be in neutral (centered) position before venicle is turned on. Paddle fault and speed pot fault. Switch vehicle off center levers and switch back on.
I suggest contact the technical service supoort to solve it.
Hope helps.
Mar 20, 2011 | Electric Mobility Golden Liteway Scooter...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
the power supply is faulty, check the following for lekages
power transistor
rectifier diodes
fusable resistors
also griver transistors
Nov 25, 2008 | Toshiba 35A44 35" TV
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
