Https://www.google.com gives suggested fixes, depending upon which model of Ricoh printer. Do you know what model of Ricoh printer has this error? Use the Comment menu to add information to your questions in order to receive suggested fixes from FIXYA unpaid volunteers.
https://www.google.com/search?q=SC899+on+Ricoh+Printer&oq=SC899+on+Ricoh+Printer&aqs=chrome..69i57j0.4207j1j8&sourceid=chrome&ie=UTF-8
Il s'agit d'une Ricoh MP C2004ex
Avec le code panne SC899-00
Je suis dans une extr?me urgence
SOURCE: Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
SOURCE: Error SC 411 appears
SC411: Separation bias error
-Definition- [B]
A separation bias leak signal is detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Discharge brush defective
You need the service manual or have a technician fix it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
SOURCE: Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
