SOURCE: Roland Camm-1 CX-24 Error Er15:RS-232Err How
Where and when do you see this error? and what operating system are you using?
SOURCE: I have a Roland Camm-1
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
