Question about Samsung Audio Players & Recorders
How do I connect surround sound system to Samsung UHD TV Series 7
    Sergeant:
  • 193 Answers
As the old saying goes - "when all else fails read the instructions:
https://www.samsung.com/sg/support/model/UA55NU7100KXXS/
Posted on Apr 21, 2019
SOURCE:
Pattods
  • 116 Answers
SOURCE: no sound through tv speakers
Well the problem is that the PS3 only allows output on one channel. So, this is only going to be optical out, or hdmi, or even AV. You only get one option for the output.
Now, if your TV has the capability.. Run the sound through the HDMI to the TV and then let the TV output the digital sound to the surround system. This will give you the option of turning off the surround and re-enabling the TV's stereo speakers.
I hope this gives you an idea of what the problem is. If I were you, I'd just do as I said. This is exactly how I have mine setup. I have a 600w sub on the surround, so late night movies can't be played on it without the neighbors being woke up. So, I simply disable the TV's output and use it's speakers. :)
Posted on Sep 13, 2008
  • 34 Answers
SOURCE: direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 21, 2008
SOURCE: no sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Posted on Mar 09, 2009
SOURCE: samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Posted on Jun 01, 2009
kerguney
  • 577 Answers
SOURCE: samsung ps wx30 surround sound
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Posted on Jun 25, 2011
Can the Curtis Htib 1002 5.1ch system be connected di4ectly to my Samsung 4k UHD TV?
Yes, but there's almost no useful purpose. The HTIB needs 5 component inputs for the surround audio. Your TV doesn't provide this. From the looks of the connections, it looks like the video is basically a low res composite RCA plug, so no HD video from a DVD player. You may be able to run the audio output on the TV to FR/FL connection to use the sub and 2 speakers. (Mini 1/8" stereo to 2 RCA plugs. (Best buy or similar)
Here is a link to download a manual:
http://www.curtisint.com/web/browser.asp?productID=HTIB1002
Product HTIB1002 CURTIS INTERNATIONAL
Jan 31, 2016 | Samsung Televison & Video
Only the back ground sound is heard, can't here what the main actors are saying, Samsung BD-P1500, HT-AS720S, and Series 7 750 TV, trying to play a DVD, Dolby Surround 5.1
If your sound is set to Surround Sound or Dolby Surround Sound and you haven't got the rest of the system set up to balance, that is why you can only hear some of the audio. Turn off the surround sound to see what I mean.
Jan 29, 2011 | Samsung Televison & Video
Ibought samsung surround sound and hooked it to the tv,but it only works when i play dvd.how can i connect to my tv so i can surround sound from tv or drem box
connect audio cables from the audio out jacks on your tv to the audio in jacks on your samsung surround. they may be labeled video 1,2 or aux. if your using a cable box the cable box may have optical or digital input jacks. your samsung surround should have a digital in jack which requires an optical cable.
Oct 21, 2009 | Samsung HT-Z310T Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
No sound from surround sound whilst tv on
Jan 24, 2009 | Samsung HT-Q100 System
Sound issues Samsung series 6
The speakers that come with built into the units are very limited at best. Better than the old 4" speaker that came in TV sets from the old days, but not by much. Ask if you are not expecting more out of the output than is reasonable.
I would offer that the true design intent is to hook the HDTV into a home surround system, a home system is optimized for and designed for your listening pleasure. I'm guessing that your HDTV is an LCD with a sound bar at the bottom, if so it is for general use and not intended for critical listening.
I have a 61" Series 7 DLP and even with larger built in speakers, the difference is night and day between my surround sound system and the HDTV stand output.
john
Aug 14, 2008 | Audio Players & Recorders
55 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
