On most 92-94 models you have a red and yellow wire coming from the inertia switch to the tank select switch if you have dual tanks, then a red wire to one pump and a brown and white to the other pump. Both pumps use orange or black for ground.
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9).
Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
if you set the t stat in VIP mode you can operate the fan manually but you shouldnt have to do this. it sounds like the t stat is losing communicatio with the HVAC reciever board.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
