I have already isolated and reconnected the battery and checked bluetooth connection on my phone
SOURCE: Bluetooth connection not working Kenwood KCA BT100 with KDC W7537U and a Nokia N95
Seen a site called Memoryking.co.uk which does all good price on memory cards
http://www.memoryking.co.uk
SOURCE: xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
SOURCE: Blackberry 8310 Bluetooth device no services
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
SOURCE: Pioneer DEH-P700BT and Nokia N95
I managed to fix this issue with the auto disconnect using a Nokia N81 and Pioneer DEH-P7050BT.
I originally had the same issues that everyone else was facing, after trying several different things I successfully auto connect my phone when i turn on the ignition switch. It still disconnects when trying to download contacts, but i transferred these instead so not a big problem there.
OK so that steps i performed in order were.
1. Download and update the head unit software update from the Pioneer website, there is a link attached in another post. Follow the steps in the instruction manual.
2. Delete the pairing from the phone
3. Update the firmware of the phone via the Nokia Software Updater.
4. Turn off the PC Suit Sync in the phone, this can be found under settings.
5. Repaired the phone and the head unit, use the NOKIA-A option not NOKIA.
6. Authorise the phone to auto connect to this BT device without prompting.
This is all the steps I tried, some may or may not be usefull but after trying different combination's, I get a successful connection each and every time. A little icon of a car will appear on the phone stating it is connected.
I hope it works for you.
SOURCE: I cannot get my Plantronics voyager520 to pair with my tmobile g1
I just did this... first make sure your old phone is off... second go to bluetooth and make sure that discovery is on and then put your plantronics in learn mode or what ever its called by turning it on and holding it until it flashes red and blue... Your phone will request a pin code.. the pin code for plantronics is 0000 then it should connect. Hope this helps
