Question about Measuring Tools & Sensors
Weather Station C83349 sensor not working. Red light does not blink. Changed batteries. What do you suggest?
SOURCE:
SOURCE: Blinking Red Light
just push the button one or two more times at will take a picture while the light is blinking red.
Posted on Apr 29, 2008
SOURCE: Honeywell Wireless Personal Weather Station
Both units (transmitter and receiver) require two AA batteries. That solved the problem!
Posted on Aug 31, 2008
SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
Posted on Oct 19, 2010
  • 30 Answers
SOURCE: skyscan atomic clock weather
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
Guide for lacrosse technology model c83349 weather station
link to manual
https://www.lacrossetechnology.com/media/catalog/product/c/8/c83332-c83349.pdf
May 15, 2018 | Measuring Tools & Sensors
Lidl/Auriol Z31601B-RX weather station
1 Weather station
1 Outdoor sensor
2 Batteries, type LR06, 1.5 V
2 Batteries, type LR03, 1.5 V
1 Set of operating instructions
Note:
First insert the batteries in the outdoor sensor, then the weather
station.
http://www.lidl-service.com/static/58242588/91679_en_da.pdf
Jan 02, 2018 | Televison & Video
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Why is there a red blinking light on outside sensor? This is only 2 weeks old and new batteries were put in then.
The red blinking light, I believe is indicating the outside sensor is transmitting the outside temperature data to main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
