It happens more when the mower has been running for a while. It runs fine when it first starts.
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
SOURCE: Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
SOURCE: the blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
SOURCE: white smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
