Garnet, I am wondering if something is causing the oil to "gel".
I remember years ago that #1 & #2 oil was mixed in cold weather to be thin enough to flow properly so the burner would work. If cold weather is not a factor, then I would suspicion that the oil is not good quality, thus causing you problems of clogging. Are you sure that there is no water from condensation in the tank? Additives might help to clear the situation.
SOURCE: i got gas leak coming from the fuel line
First off, what kind of vehicle do you have? I assume it is one that has an electric fuel pump in the gas tank, so that is what my answer will be geared to.
On the gas tank there are several lines. The most important ones for this conversation are the ones that deliver fuel to the engine and the one that returns the excess fuel back to the tank. They are usually different in size.
The larger one delivers the fuel and the smaller one returns the excess fuel back to the tank. Either one may be the culprit in this scenero.The tank is usually connected by a high pressure flexible fuel line to a stainless fuel line resembeling a brake line. At times this flex line may develope a leak for varrious reasons. It could be something rubbing against the line, it could be the crimped connection went bad and is leaking, etc. If it is your flex line, which it probably is there is a repair kit you can purchase to fix it. I have only been able to find this repair kit at NAPA. I've tried many auto parts stores and they are the only ones that carry it. The use of it is very simple actually. You find the leak in your line, which by the way is harder than it sounds and usually involves removing the gas tank. In which case you will need a special tool to disasemble the gas line from the tank. Once the leak is located you cut the line. You then have to place the remaining flex hose in boiling hot water for at least 10 seconds, which makes it soft and insert a splice fiting into it. When the line cools, it will shrink tight on the connector. You the do the same with the hose that came with the repair kit. Then do the same with the other end and install the fitting which connects to the gas tank. You should now be in business.
BTW. I have to do this very thing tomorrow.
Good Luck! and let me know if this helps you.
SOURCE: Seems to be clogged.Is there anyway to flush or
Try putting white vinegar in it, and letting it soak. For more cleaning, you can recirculate the white vinegar back through the machine, but strain it through a coffee filter first to remove any sediment that you break free. Once you're satisfied with your cleaning, flush the tea maker with pots of fresh water, until no vinegar can be detected by taste or smell.
Best regards, --W/D--
SOURCE: Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
SOURCE: Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
SOURCE: i think the fuel pump on my beckett burner is
As you face the burner, mounted in the unit, the oil line feed in on the left side. There is a cap, held on by 4 7/16" bolts. Inder the cap, there is a screen. You would be best to get a screen kit, available from the same place you get your nozzle, as it will come with a new gasket.
Shut off the oil. Remove the four bolts, pull the old screen, clean the housing (I use rags and WD40) and re-asssemble. If is is really bad, you should remove the nozzle assembley and flush the oil line to the nozzle, as well.
THe oil filter, screen and nozzle should be replaced at least once a year.
