Still won't download channels. Help please. Regards Gary
SOURCE: i need help tv lcd akai model lct2785ta
You do know that this model TV takes about 5-10 seconds to come on after you press the on button, right?
Press it once to get the green LED, then wait. If it doesn't display the blue AKAI splash screen within 15 seconds, the TV is not working as it should.
Also remember that this model has two RF input jacks. As seen from the back of the TV, the jack on the far right is the one to use for analog TV, analog cable, coax out to TV from a cable box, or rf out from a vcr.
Don't use the one on the far left. It is for input to the ATSC OTA DTV tuner only.
Most likely there is a real problem with your TV, but in the video, you are pressing the on/off button in rapid succession. That will never work with this model.
SOURCE: NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
SOURCE: After having to retune my Alba Freeview Digital
You may need a better aerial. Digital TV signals need good signals or you can't pick up the full range of channels. Broadcasters and others are tending to keep their mouths shut about the expense of needing much better things on the roof than what many people use to get away with on analog signals. Even if you have a good aerial, If you have the 'brown' coax cable connected to it you could lose signal and stations. So it's best to replace it with Satellite coax cable FT100. That should stop a lot of blocking caused by interfearance by cars or those off road bikes youths ride around on.
SOURCE: SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
SOURCE: WILL NOT ALLOW LCD CLOCK TO RESET
Turn it on and while its on completely unplug it wait then replug it, this should reset it, if this does not work, and it should, you will probally have to replace timer, but I hate to recommend this, they do not go bad ofen, but on acasion they do, let me know i hope this does it without replacing the timer
