Question about Hitachi Televison & Video
Need help taking my 2 pc Hitachi 57g500 tv top portion on the base Have instructions but don't understand RON
SOURCE:
  • 275 Answers
SOURCE: hitachi 57g500 vertical problem
Yup you are getting ripped off. Get another techie to have a look.
Posted on Sep 25, 2006
SOURCE: Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Posted on Aug 18, 2008
  • 8457 Answers
SOURCE: Hitachi 57G500 the green has dipped down in the color grid
U can't adjust this,Ur convergence is dead.U know how to solder?Buy ur tv name and brand the covergence kit,replace what the parts in that kit.
Posted on Sep 24, 2009
  • 8457 Answers
SOURCE: Auto Digital Convergence Adjustment blue to aligning
Ur convergence is dead.Buy the convergence kit,replace what in that kit.Tries these websites Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
SOURCE: How to disassemble an old Hitachi projection TV (model 53sbx59b)
To remove the protection screen and lens from my Hitachi model 53SDX89BA:
1) Remove the speaker cover from the bottom. It is attached by velcro.
2) Remove the 4 screws on 4 plastic tabs on the bottom of the screen frame.
3) Remove the 4 screws on the 4 metal tabs on the bottom beneath the screen frame.
4) Pry the bottom corners loose with a wide blade screw driver and work both sides of the screen frame away from the case from the bottom up. CAUTION: The top does not snap away as the sides do. When the sides are loose let the screen frame hang down vertical and lift the screen frame straight up.
5) The protection screen and the lens will come off together.
When reinstalling the screen frame perform the steps in reverse. Be careful when resnapping the frame back onto the case - there are two small wooden support blocks on the bottom. Don't try to force the frame back on until you are sure the bottom of the frame clears these block. You may find it easier just to remove them temporarily until the frame is reattached.
Posted on Jun 09, 2010
Magic focus/convergence/blurred double images
Try to get an electricians help or contact a TV repair specialist.
Oct 26, 2013 | Hitachi 57G500 57" TV
Hitachi 57G500 57" TV has no picture but has sound
I need codes for a new remote(hype jumbo 3-in-1)hy-409-ipd
Jul 05, 2012 | Hitachi 57G500 57" TV
I have a 54 inch Hitachi 57G500. The picture is now showing double on the blue spectrum color and auto magic focus is not fixing it.
Most likely this set has bad convergence amp ic's and some open resistors. This can be a very tricky repair. Check:
resistors RK42, RK46,
RK50, RK54, RK58, RK62
Output STKs IK04, IK05.
Hopefully this will help. Thanks for using fixya.
Jan 14, 2010 | Hitachi 57G500 57" TV
I need a replacement remote what is the remote modell number for 57G500A and where can i get one
hl01834.gif HITACHI HL01834 REMOTE CONTROL REMOTE CONTROL (CLU421UG) $51.14
In Canada the part is available at globalsemi.com
Oct 31, 2009 | Hitachi 57G500 57" TV
Sep 24, 2009 | Hitachi 57G500 57" TV
Mar 16, 2009 | Hitachi 57G500 57" TV
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Hitachi 57G500a no picture but has sound
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Sound but no picture
Check the LOT cable for short circuit
Nov 24, 2007 | Hitachi 57G500 57" TV
Hitachi 57g500 vertical problem
Sep 24, 2006 | Hitachi 57G500 57" TV
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
