Question about Hitachi Televison & Video
I have a big 57in" hitachi tv floor hdtv #57g500.
I have to remove top part of tv because can't get upstairs ASAP I have te instructions but can't figure out!!
SOURCE:
marked
  • 6487 Answers
SOURCE: HDMI from laptop to DVI plug on Hitachi big screen TV
To fix it, just turn the set off, let it discharge for a few hours. Reach in and remove the socket from the back of the tube and reinsert a few times to break through the corrosion.
This is a sign of weakness in the manufacturer of the guns and the connecting sockets. The metal used in the pin connections inside the socket are corroding and when you remove the socket and reinsert it cuts through the corrosion and makes good
contact again.
If still not working contact the support for your television..
Hope that helps......
Posted on Jul 06, 2008
tvguy171
  • 106 Answers
SOURCE: Hitachi 65 Inch HDTV (2006) Model
Are these circles at the center or in the corners. Can you see them on blank screen such as input 1 with out anything hooked up to that input. If so, you are looking at a light engine.
Posted on Nov 26, 2008
  • 4 Answers
SOURCE: color problems with Hitachi 57in rear projection
One or more of the projectors lights( my guess is the green one) are either blown or in the process of going bad. Have them repaired or replqaced by an authorized tech.
Posted on Dec 30, 2008
  • 1039 Answers
SOURCE: No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Posted on Apr 27, 2009
  • 12 Answers
SOURCE: the tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
Posted on Jun 13, 2009
Hitachi 57G500 57" TV has no picture but has sound
I need codes for a new remote(hype jumbo 3-in-1)hy-409-ipd
Jul 05, 2012 | Hitachi 57G500 57" TV
I have a crackin my projection screen tv! its a 57in and I would like to know how much would it be to get a new screen?
You are going to most likely find Hitachi sells (if still available) only both screens as a assembly.
Try calling ANDREWS ELECTRONICS in L.A.----they have a 800 number and are also on the internet;
Jun 06, 2011 | Hitachi 57F500 57" Rear Projection...
I have lines on the bottom of my 57in rear projection hitachi tv how do i get rid of them myself
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 57F500 57" Rear Projection...
I have a 54 inch Hitachi 57G500. The picture is now showing double on the blue spectrum color and auto magic focus is not fixing it.
Most likely this set has bad convergence amp ic's and some open resistors. This can be a very tricky repair. Check:
resistors RK42, RK46,
RK50, RK54, RK58, RK62
Output STKs IK04, IK05.
Hopefully this will help. Thanks for using fixya.
Jan 14, 2010 | Hitachi 57G500 57" TV
Hitachi 57G500 the green has dipped down in the color grid
U can't adjust this,Ur convergence is dead.U know how to solder?Buy ur tv name and brand the covergence kit,replace what the parts in that kit.
Sep 24, 2009 | Hitachi 57G500 57" TV
Auto Digital Convergence Adjustment blue to aligning
Ur convergence is dead.Buy the convergence kit,replace what in that kit.Tries these websites Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Mar 16, 2009 | Hitachi 57G500 57" TV
I have a Hitachi 57in projection color television. The problem I have is that when the set is turned on there is a click but no picture or sound.
Ur DM power board is dead.Have burns capacitors,check for puff up capacitors.Buy capacitors parts for replacement to rebuild board.Tries thes websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Jan 30, 2009 | Hitachi 57G500 57" TV
Color problems with Hitachi 57in rear projection
Dec 28, 2008 | Hitachi 57F500 57" Rear Projection...
Trying to swith to cable mode
lift lid on front of tv just above the red power light. press the far right button labelled select. press exit to remove menu. use up and down arrows to navigate. you can download user manual from hitachi.com website.
Oct 10, 2007 | Hitachi 57G500 57" TV
Hitachi 57g500 vertical problem
Yup you are getting ripped off. Get another techie to have a look.
Sep 24, 2006 | Hitachi 57G500 57" TV
Televison & Video Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
