My dell latitude older model only boots in safe mode now; when I do a normal boot, it blue screens N says inaccessible boot device whether i use a battery or charger.
Win 10 does load in safe mode, but after doing the repair mode procedure. could it possible be a corrupted BIOS ?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
If it's that old, the bios battery could be depleted
Posted on Apr 20, 2019
  • 1 more comment
  • Mitch Central Apr 20, 2019
    no, thats not it because it gets past the BIOS, plus the date is right everytime proving the clock battery is good. n at times pc will load ok without blue screening, but when i restart it will bluescreen as long as it is plugged in.
    thanx tho
  • esar Apr 21, 2019
    failing hard drive, is there any ref to s.m.a.r.t. in the bios?
    Welcome Back:
  • 60 Answers
How OLD a Dell latitude? More likely a bad hard drive or screwed up win10 OS (after all, it IS win10)
Posted on Apr 21, 2019
SOURCE:
  • 31 Answers
SOURCE: Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Posted on Dec 15, 2007
mewms_14904
  • 1027 Answers
SOURCE: Dell 4500S Desktop doesn't boot Windows
Sounds like a ram problem.
Posted on May 10, 2008
christofritz
  • 55 Answers
SOURCE: Dell Latitude model ppx Latitude C family won't boot up
It is a hardware problem most likely or maybe no operating system, but most likely the devices not being connected. to the mainboard and such. if you have a warranty call dell or go to their website at http://support.dell.com/
Posted on Oct 26, 2008
  • 14 Answers
SOURCE: Blue screen of death
Taken from Microsoft themselves ( http://support.microsoft.com/kb/555302 )
SYMPTOMS
When booting up to Win XP you may get a error that reads "Unmountable Boot
CAUSE
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
RESOLUTION
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Jan 26, 2009
  • 145 Answers
SOURCE: Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Posted on Oct 16, 2009
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Netbook will not boot up ,keep getting blue screen saying could not boot up then goes back onto normal boot screen then goes onto black screen asking whether to boot up normally or in safe mode
you have a corrupted operating system, please restore the laptop by pressing Alt+F10 immediately after pressing the power button and follow the screen.
Hope this helps
Apr 06, 2010 | Acer Aspire One PC Notebook
Blue screen was appearing while booting the system
This is a driver issue, try this. Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 04, 2010 | Dell Latitude D600 Notebook
I av a dell latitude c500/600 and need the usb driver its running on xp cheers
All drivers for XP in the C600/C500 should be native to Windows XP Dell never shipped XP on that model so they never had any drivers for XP.
If you have issue with USB devices on that model, try booting to the safe mode, remove the USB devices in Device Manager, then reboot in normal mode and let them re-detect.
Dec 05, 2009 | Dell Latitude C500 (LATC500) PC Notebook
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
Will not reboot...continues to go back to "We apologize for the inconvenience screen"
First, see if you can run diagnostics from the F12 menu or from the Dell Resource CD and see if the HDD or any other hardware indicates a failure. If you are having a hardware failure, there is no point in trying to fix a software issue until the hardware is fixed.
If the HDD fails diags, replace it. If it passes, then try booting to the XP CD, and see if you can boot to recovery console, and run CHkDSK /R
Apr 14, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Computers & Internet Logo
Alun Cox
