I want it to stay where i set the volume
SOURCE: The Volume turns down by itself
Just make sure it in Home mode not store mode,to do this unplug the TV for 10 min. or so then when you plug it back in turn on the set and you will see HOME/Store then pick Home.Hope this help's
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
SOURCE: kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
SOURCE: Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
SOURCE: I have a kenwood radio model kdc-135 and can not set clock or sh
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-135.pdf Here's the manual link from Kenwood and it's on page 13. Hope this helps
