Hi, i have an old Toshiba 1300. after i connect it to power it just restart. I noticed that in battery mode runs just fine. What can i do to fix the laptop?
SOURCE: cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
SOURCE: toshiba satellite L300 laptop sound drivers on XP do not work
try going to there web site and down loading driver and install.good luck
SOURCE: Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
SOURCE: Toshiba Satellite Pro L300 PC
you should have your unit check professionally, as it can be cause by multiple problem.
1. laptop fan
2. memory problem
3. voltage problem.
either way, its best that you try to have it check thru the toshiba service center.
SOURCE: hi i have a toshiba satellite l300 the battery
For Award BIOS' try these backdoor passwords:
For AMI BIOS' try these backdoor passwords:
For PHOENIX BIOS' try this backdoor password:
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
phoenix
