SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
SOURCE: Nokia 5330-1d dstv
hi sir/madam,am john chat with u from ghana my nokia 5330-1d tv is not working why
SOURCE: My TV is not responding when I press my DSTV remote
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: how do i download showmax for hisense smart tv
If you type "showmax on hisense smart TV" in google it will give you several sites that tell you how to set it up. One claims to only take 2 minutes. Give this a try.
