The error messege says "Non-System disk or disk error replace and strike any key when ready".
SOURCE: Compaq Armada M700 - failure to boot from CD
Hello Blessie,
This is Romeet,i shall try and help you with this problem. Before formatting for a new installation of w2k, did you delete your partitions and create a new partition or did you just overwrite the old installation partition?Besides i hope you did a backup of your data before any of above processes in the event you might need it later on? Please let me know about the partitioning and i shall try and help further accordingly as most likely it looks like a Disk Partitioning Misconfiguration / Problem
Regds
Romeet
SOURCE: compac presario 1500
You need to reboot using the first disc in the series. Make sure that the AC adapter is plugged in, and check your bios settings and disable any power managment settings, in order to prevent the machine from going into standby, sleep, etc.
You should be able to make it through the entire series. If you can't, you may need to contact HP for a new set of discs, or if you have an HP authorized service provider, such as a Staples, Best Buy, etc; they can usually get the CDs a lot faster, and usually at the same cost, or maybe a little higher.
SOURCE: issues with my compaq armada
Hello Mitchiko
This error message is often the result of corruption on your hard disk. Quite likely including the MBR.
This could indicate your hard disk is failing or just that there was a glitch in your system that caused your MBR to be over-written or corrupted. In any event, w/ an error like this, you're going to need to ...
(01) Test your hard disk to make sure it's OK
(02) Attempt to restore your MBR
There are some great (free) MBR tools HERE.
There's a nice article HERE on "How to Repair your MBR". The author does a nice job of explaining what the MBR is and how to repair it.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc. on this topic.
Thank you
BJ
SOURCE: compaq evo n610
Your problem is that MOTHERBOARD can't detected HDD.Try with another hdd and let me know if it works!!!
SOURCE: Please help me with my COMPAQ ARMADA 1700
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
