Question about Measuring Tools & Sensors
Where can i order an outdoor sensor for the accurate model # 02483
    Top Expert:
  • 63,373 Answers
SUGGEST YOU TRY THE MFG'S WEBSITE OR ASK Google
Posted on Apr 19, 2019
Testimonial: "I have tried everything and still no answers"
  • 1 more comment
  • ray gallant
    ray gallant Apr 19, 2019
    YOU COULD JUST BUY A COMPLETE NEW UNIT .
  • Dinah Miller
    Dinah Miller Apr 19, 2019
    the unit I have is brand new but the outdoor sensor is missing so I am looking to buy just the outdoor sensor
  • ray gallant
    call the manufacturer ot the place you bought it we can not help you with missing new parts here
2 Suggested Answers
SOURCE:
SOURCE: I own a Nexxtech Wireless
The out side temperture is appearing as 3 or 4 dashes across the display. What is the problem and how do I repair it?
Thank you
Jerry
Posted on Sep 05, 2011
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
Is there censor available for a 308-2316 weather station that will make the outdoor temp more accurate?
The most important things to remember with weather stations are placement and battery power. To get an accurate reading, you must have the sensors in the proper spot. If they are on a roof, they must be at least 3 feet above the roof. The batteries should be changed yearly and replaced with Lithium type batteries. Your sensor suite is a combination of anemometer and thermo-hygrometer. You may be able to purchase another temp sensor. The manual shows multiple channels for that application. Send them a message and ask: http://www.lacrossetechnology.com/support/contact_lacrosse.php
Mar 16, 2015 | Measuring Tools & Sensors
Error code CH 02. Since this LG model has been discontinued I am looking to repair if possible. Thermistor error but which one and can I just order a new one and simply unplug the old and plug in the new?...
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5 kOhm
at 25C. If not replace sensor.
Very easy to replace, just make sure power is off and wait 10 mins for capacitors to discharge then swap over thermistor and power up.
Mar 15, 2015 | LG LMN125HVT Air Conditioner
National geographic weather trouble shooting
The order of replacing batteries is important. The outdoor unit batteries first, then the indoor. You wait 10 minutes until the outdoor unit starts sending data.
Jun 16, 2014 | Televison & Video
Code A3 bad outdoor coil temp sensor
Need a model number for the outdoor unit. The sensor should have a part number tag on the sensor wire.
Dec 19, 2013 | Goodman Heating & Cooling
Propert Digital bathroom scales only reads half of body weight
If you want to measure accurate weight of your body, then you should to use Omron HN-286 Digital Slimline Bathroom Scale which uses 4 sensors for greater precision in order to accurately measure body weight.
Sep 04, 2013 | LG DVD 5095 DVD Player
Measuring Tools & Sensors Logo
44 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
