Question about Measuring Tools & Sensors
I need to find an outdoor sensor for my ACURITE weather station MODEL #02483.I have looked on your site as well as Amazon and have found some outdoor sensors but none that are for this Model#
    Top Expert:
  • 25,056 Answers
Have you called acurite?
Posted on Apr 19, 2019
Testimonial: "There is no way to talk to a live human when you call their the ACURITE # instead they refer you to this place in order to ask questions which you can't always get an answer to."
  •  steve
    steve Apr 19, 2019
    you may have to find a dealer who actually sells just the outside unit. it may not be available. this is a repair website really we are not a part of accurite at all.
3 Suggested Answers
SOURCE:
emissionwiz
  • 85020 Answers
SOURCE: Lacrosse weather station model T85647
Either the sensor is defective or the receiver is, toss a coin.
Posted on Jun 30, 2017
  • 18060 Answers
SOURCE: I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Posted on Apr 01, 2018
Can I download an owners manual for a dr tech WF-1070T outdoor sensor?
Not found it so far but here is a book for a 1050 model, much of which is transferable. There is no Dr. Tech website per se where you can get support or download a manual. That means you would have to depend upon hobbyist/blogs or look up information in generic sites about factors in weather if you have a question. Here is a site where you might try some queries:
http://www.weather-watch.com/smf/index.php?topic=53707.0
http://site.ambientweatherstore.com/Manuals/wh1050.pdf
https://www.rakuten.com/prod/dr-tech-professional-wireless-weather-station-w-solar-transmitter/230818678.html
Sep 09, 2017 | Universal WS1065 4.9"" LCD Wireless...
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Acurite weather station not working,flashing off and on
In order to best troubleshoot this, we would need the model number of your unit. This can typically be found on the back of the display, or the front page of the instruction booklet. To find more information and troubleshooting tips on any of our units, please visit http://www.acurite.com/kbase.
Mar 31, 2015 | Measuring Tools & Sensors
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
Nov 01, 2014 | Acu-Rite Acurite Wireless Weather...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
52 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
