Question about Exercise & Fitness
I have a Horizon CT7.1 treadmill. When I turn it on it just beeps. Nothing happens. No controls work
SOURCE:
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Posted on Jun 03, 2009
valiantma595
  • 176 Answers
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Posted on Sep 23, 2009
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Horizon Treadmill won't run?
Check this attached link for trouble shooting information
May 31, 2014 | Horizon Fitness T101 Treadmill
Ti22. Power turned on display screen blue but no text display. No controls work, no beeps when any buttons pushed.
Power board may have shorted. Check all fuses and connections. Check for loose wires. May need professional services.
Mar 17, 2014 | Horizon treadmill Ti 22
How to disable the beeping on a Horizon T61??
RUN the software calibration for easy diagnose, troubleshooting, and fix it.
However read your owner manual and follow the instruction in troubleshooting section, how to disable the beep.
Test the speed sensor+ reed switch, for open or defective, CLEAN it and tight any plug or connector.
see the block diagram
God bless you
Nov 17, 2012 | Horizon T61 Treadmill
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
