SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
SOURCE: wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
SOURCE: EuroTech EWC177 washer/dryer combo reset
tinaheinleHello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, ..well this is a solution.....
my roommate unplugged the machine while
it was drying. the start and spin lights were both flashing. I called
the company and they told me to reset it, but the weren't sure how, lol.
I
unplugged it and waiting, nothing. I flipped the breaker, nothing. I
finally turned it to a setting, and turned on nob on the dry, and it
started clicking.
I turned off the dry, and hit the start button, and it started right up...
If the next time you use it and it's fine then you did succeed in resetting the system and will be alright!
Let me know that we were successful!
Please remember to leave a rating before you go!
Thank you
SOURCE: error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
SOURCE: Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
