Try unplugging it and plugging it back in
Hi Kamran, do you have the remote control to test the operation? If the remote control works and the device does not respond, you will probably have a problem in your Onkio's function zone.
Find a specialized technical service
Greetings Franco Dosil
Hola Kamran, tienes el control remoto para probar el funcionamiento?, si el control remoto funciona y el aparato no responde, seguramente tendras un problema en zona de funciones de tu Onkio
Busca un servicio tecnico especializado
Saludos Franco Dosil
SOURCE: Kenwood RXD-A53 CD player just rotates and doesn't load a CD
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Testimonial: "Super quick response, haven't tried the solution but I will, Thanx!"
SOURCE: satio touch screen not responding at all? buttons
Ur problem is because of short circuit inside ur phone .u cann't solve this problem on ur own u have to go to nearest mobile service center.
