I realize that when using any cycle on my washer that whenever I chose one of the wash options HEAVY, NORMAL, or LIGHT, the wash time will be adjusted and as well when I add extra rinse or spin to that cycle. When I'm washing my husband's dirty clothes in my Samsung front load HE WF45N5300, I've selected the normal cycle, heavy wash, extra wash and extra spin. The total time display is 1 hour, 50 minutes but the machine is automatically extending it to more than that time after the wash cycle has begun. Instead of a cycle of 1 hour and 50 minutes, it is somewhere between 2 hours and 50 minutes or possibly 3 hours and 50 minutes. Will verify the exact total cycle time when I do another load. Is the machine weighing the clothes to adjust the cycle time and why? It's very frustrating when I do this type load of an evening and have to stay up late to finish the wash and dry before bed. I had a Samsung WF328AAW and the wash cycle for HEAVY with an extra wash, rinse and spin was no where near 1 hour and 50 minutes to begin with and never automatically extended the wash cycle time, until the washer was on its last leg and had numerous issues.
The given details about the washing machine problem are also happening with many users and they also do not know how to make it solved. The repair is necessary in this case and the similar issue I have also gone through and took the help of https://uaetechnician.ae/washing-machine-repair
SOURCE: Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
SOURCE: LG WM-3677HW dryer cycle does not dry and lasts for 3 minutes
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl ...........if helped.
SOURCE: GE Prodigy washer
my prodigy model # GZ133379G is only going one way not back and fort and it smells let rubber burning how can I fix it
SOURCE: won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
