SOURCE: power light flashes twice,then opc flashes once then power again
In all the time that you have had the tv have you applied 2 firmware updates that some of the tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I don't know if this is the case for you but it worked for me. Call Sharp at 1-800-237-4277.
SOURCE: What does it mean when the red engine light
This could be (likely is) an oil pressure issue.
Do a complete oil change including filter.
SOURCE: I had my transmission replaced
It is the "Check Transaxle/Transmission" light.
Ensure your transmission fluid is at the appropriate level, as it should be checked at least once after any transmission service is conducted. Low fluid will cause the light to go on when you come to a stop and the fluid level moves forward, exposing momentarily the low level sensor.
If your level is correct and the issue is still occurring, there is a problem within your transmission and it should be brought back to the people who replaced your transmission.
The dipstick for a mercury sable is located behind the motor, and is a hard to see (usually black) circle dipstick. Do not mistake it for the oil dipstick located in the front, transmission fluid is red. The stick could also be, yellow, or red. Bring a light.
The fluid level should be in BETWEEN the cross hatch pattern on the metal stick when the car has not been running.
SOURCE: red light flashes once then 2 fast
Hello, welcome to Fixya!
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
SOURCE: I have a 2003 Mercury
It is the low coolant indicator. Mine has been blinking for years, no codes thrown, replaced thermostat, etc. topped off coolant, it stopped... popped my radiator, steamed over, light blinking again, top it off, it stops... when it leaks out it blinks. Why can't FORD (I love Ford, i really do) mail out a notice to people saying this, and that the radios in their 2007 cars will eat their CD's and not give them back.
