If the washer agitates, but does not spin and empty, it is most likely the switch that is activated by closing the lid. Those Kenmores from that time had a problem with the bracket cracking on that switch and then it would come loose and could not be activated. If it will not agitate, spin or empty, it is most likely the clutch, which kind of looks like a hockey puck with six holes in it. If you’re handy at all it is about a $20 part, and about 1/2 hour of work.
SOURCE: Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
SOURCE: loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
SOURCE: I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: My Kenmore high efficiency 3.5
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
SOURCE: kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
