Make sure the back of the watch is spotless and your skin isn't too dry.
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
SOURCE: I lost my bowflex watch
That is such a specific type of watch you will have to contact them at the following link:
https://www.heart-rate-watch.net/contact-us?osCsid=18b0055ce5db1b2b4eba5e48cb5eeb1e
Best wishes
SOURCE: garmin edge 305 heart rate sensor does not work
the rescan worked for me, didn't know it existed, briljant. Follow list below:settings/system/accessoires/rescan
I love google today;o)
