When it goes dark can shine a Bright light on the screen and see the image being displayed. When I turn off computer, Monitor will display "Check Signal Cable" Screen saver box (2"x4") with normal brightness. Have tried this on 2 Computers.
There is a very good answer to your monitor issue found here:
http://www.fixya.com/support/t467725-samsung_lcd_monitor_syncmaster_203b
SOURCE: Monitor displays breifly then goes to blank screen
Well my Acer AL1711 finally gave up in as much as the screen flashed briefly at switch-on then went blank, regardless of brilliance setting so I decided to take it apart and try to fix it. The good news is that IT WAS NOT THE LAMPS that I feared in my earlier post and was easier than I had ever dreamed! First allow a good period of time for the internal components to discharge before starting. Remove the plastic clip at the base hinge to expose 4 screws - remove all four to release the stand. Then remove the 4 black cross head screws that appear to hold the back on, they do but there is more to do. Carefully tease the silver surround away from the case, best to start in the centre of each side and finish at the corners. There are many plastic clips to release before the surround comes away. Now remove the four cross head screws holding the pushbutton switch circuit board. The whole assembly can now be removed from the case and reveal a metal cover held by 2 SHORT (remember that!) SHORT! threaded machine screws. These once removed will allow the case to be slid away from the holding tabs located down the edges of the cover and removed. Now unplug the connectors from the board that has the mains input connector attached to it. You will see a heatsink with 4 electrolytic caps above it. Silly ACER designers, have placed the capacitors so that they get all the heat from the heatsink! Yes folks, the capacitors are above the heatsink when the monitor is in its normal operating position! So all the convected heat dries them out, nice. So the fault is due to a silly design error! Replace all 4 capacitors, two of them are 1000uF at 16V and the other two are 470uF at 16V, all radial types. Try and get capacitors with the highest operating temperature, at least 105 degree types and remember these are polarised, make sure you connect the capacitor + wire to + on the circuit board. You should have no problems with re-assembly but don't put the wrong screw where the short ones went or you are liable to see it come out of the screen LOL! Most important - - Don't forget the screw holding the earth tag to chassis. Good Luck, you will be amazed how much brighter the screen is now!
SOURCE: Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
SOURCE: Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
The green power light indicates that the monitor is receiving from the
computer correctly. I suspect it is going into high voltage
shutdown. There is a safety circuit that monitors the high
voltage and shuts the monitor down if it sees anything amiss. So
the monitor comes on and then shuts off. High voltage problems
are generally not worth trying to repair. Another example of a
worthless safety feature. High voltage failures are not
dangerous, and adding the safety circuit just kills the unit when it
may have some life left or worse, sometimes it is the shutdown circuit
itself which fails!
Hope this helps.
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
