Question about Radio Communications
Enacfire bluetooth E18 ear buds no longer allowing to pause or resume by pushing button
    Top Expert:
  • Radio Commun... Master
  • 51,910 Answers
The button may have failed.
Posted on Apr 18, 2019
SOURCE:
SOURCE: pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Posted on Jul 24, 2007
eradiostore
  • 1655 Answers
SOURCE: Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Posted on Dec 08, 2008
SOURCE: Ear hook and ear bud replacements for Motorola H375
Here a site for replacements.
MOTOROLA H500 REPLACEMENT EAR HOOK $4.50http://www.worldwidecelldeals.com/store/
Posted on Apr 02, 2009
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
kjwmartinez
SOURCE: Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Posted on Apr 13, 2012
User manual enacfire e18 wireless ear buds?
Try Googling (enacfire)(e18)(manual) without parens.
May 06, 2018 | Audio Players & Recorders
Can't connect my ear buds to Bluetooth
Push and hold the on button for 5+ seconds until the bluetooth light stays on. Then scan with your phone.
Mar 06, 2018 | Radio Communications
What do all the symbols on a roku remote do
Which remote do you have? The * symbol is used to delete a channel that you no longer wantThe three buttons that look the same as on a VCR remote operate similarly. The pause / resume button will pause and resume so if you have to answer the phone or check on the baby, you can use the pause / resume button so you won't miss anything The fast forward and reverse button works on some movies, but not all.
Jan 03, 2017 | Roku Televison & Video
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Connect a 3.5mm ear bud jack
Fair warning, this response may be a dead end & be a waste of time. I can only refer you. In attempting to find a fix to your problem I did a little research. I am not sure that what I am telling you is even allowed on this site. On YouTube, type in ' Connect stereo to earbuds on BMW1200LT'. there is a vid showing stereo install. It may help. Sorry, I am a hardwire tech not a wireless guy.
Dec 25, 2013 | 2000-2009 BMW K1200LT Brake Pads
How do I replace ear buds on electronics 520?
There are no replacement earbuds for Plantronics Voyager 520. You would need to replace the headset if the earbuds are making it uncomfortable enough that the headset is unusable. Link to Headsets Direct Bluetooth Headsets is included below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Rental...no manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
Nov 07, 2009 | Washing Machines
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
