Computers & Internet Logo
k
khanyiso Posted on Apr 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many pc's can be connected to a ups - Computers & Internet
goneforever.
Level 3:
Top Expert:
  • Computers & ... Master 14,531 Answers
  • Posted on Apr 18, 2019
goneforever.
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263692
Points
66315
Hello KHAN
this is easy ,just simple math. (or touch of ohms laws)
NO PC stated, Nor monitors., maker and models.
no UPS stated. maker and model
each PC as a watts rating (we measure it)
then each UPS has total power rating
then there is RUN time.
what run time do you wish,? 1min. 1 hour, 1day? what?
the manual for your UPS covers this.
but if 10 PC used 100watts you need at least 1000Watt UPS.
10 times 100 = 1000 math.
but the run time will be short.
To gain run time longer, RTM read your UPS manual and read the page called RUN TIME at a given load in watts.
the whole purpose of a UPS is run time at a AC power blackout.
How do i connect my ups to my pc
Connect your PC power plug to the UPS, connect the UPS to the mains. Connect the usb lead from the UPS to your PC. Install the software on your PC. When you lose mains power the UPS will keep your PC alive long enough for an ordered shutdown.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I am trying to connect my usb um185c to my ps3 but it doesnt work how do i connect my um185c modem to the playstation 3 without an ethernet cable
You can only do it by connecting your PS3 to PC with an Ethernet cable
- Connect Ethernet cable to PC and PS3, go to start menu>>network & internet connections>>network connections
- Right click Cricket Broadband Connection>>Properties>>Advanced Tab>>Click on allow other network users to connect through his connection>>Click OK
- Click create a new connection under Network Tasks in Network Connections window
- Connection Wizard comes up >>Click Next Click Set up home/office network
- Click Finish>>Click Next 2x>> If found disconnected hardware comes up click Ignore box
- Click Next>>Click This computer connects directly to internet(1st option)>>Click next
- Select Cricket BB>>Next>>Select Ethernet Connection that shows up, deselect any other that may appear>>Click Next 3x
- Turn on File and Printer Sharing>>Click Next 2x>>Click Finish
- Must restart PC to apply settings
- Once PC restarts Start menu>>Control Panel>>Network and Internet connections>>Network Connections
- Right click Cricket BB>>Properties>>Advanced Tab>>Firewall Settings>>Click to off
- Do same for ne LAN connection. Right click>>Properties>>Advanced Tab>>Firewall settings>>Click to Off
Restart PC again, as it is booting up turn on ps3>>Connect to Cricket BB
Then on PS3 go to Network Settings>>Set up connection>>Easy>>Hit X for everything that comes up, test connection and DONE
How do i connect dial up connection
If you want to connect your pc/laptop with a dial-up connection you need to make a dial up connection but you didn't mention your operating system.But no problem just go to control panel and there you find network connections in it you notice a create a new connection then new wizard will open press next then select which ever connection you want make then it ask how to connect to internet in it choose set up connection manually press next then choose appropriate option then its done. Your connection is just made up try to connect and you internet will start working.
Dial up connection ok but wireless will not open explorer Dell computer 2000XP Eircom connection
The dial up connection may be corrupt
delete the dial all the existing dial up connections from
internet explorer>Tools>internet options>Connections>
remove existing dial connections in Dial up and virtual private network settings
add a new dial up conection and set it up again
It show be up and running
2answers
3helpful
2answers
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
How do i hook a mac to a PC using the D-Link? I need help ASAP!
Hi, basically it really doesn't matter what sort of PC ya using... when ya connect up to the WiFi Router, the PC "Detects the SSID" (An SSID is just a unique name say.. My_WiFi) of said Router, and then with the "Remote" Computer, you simply look for, and then connect to, that network. The DHCP address server in the Router will automatically assign the "Remote" PC a WiFi address.. and from then on it doesn't really matter what any other Operating Systems the PC's are using as you are not actually connecting to them, per se, but rather conecting thru the WiFi Router to the internet. To access other PC's Windows "Files & Data" from a "Mac" & vice versa, is a slightly different matter.. but still easy to set up. The links below will be of assistance to you in setting it all up. www.macdevcenter.com/pub/a/mac/2002/11/19/mac_pc.html - 26k lifehacker.com/software/networking/connect-your-mac-to-a-windows-network-211108.php The best way to connect up a Modem & separate WiFi Router... is: Connect Modem to Router, Router to A "Main" PC, via Ethernet cable. (Router set to DCHP Server & assign an SSID) All Other PC's connect to the "WiFi Router". After setting up an "Unsecured Network" & when & after, it is all working. THEN one can set up WEP security keys for the WiFi network.
Grand Canyon Tech
Grand Canyon Tech
