A 2002 , 17 year old relic, why even mess with it. not DS100
but DS10
the relic manual is here, RTM?
https://www.manualslib.com/manual/30202/Compaq-Alphaserver-Ds10.html
SOURCE: No display
hi sucb Clear nvram and replace memory then checked it will work. there is one black button on system board plz locate it and by pressing it put power on after the display comes update the firmware and bios. pls be free for any assist thanks
SOURCE: compaq 252608-001 motherboard
Its not written on the board...
All that's written on it is the P codes, which are damn hard to read as it is, never mind trying to read anything on it...
Spkr and HDLED, and PWRLED are all marked, but the pwr and reset arent... or if they are, i cant find them
SOURCE: How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
SOURCE: power light flashing
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
SOURCE: How 2 plug-in power button+LED, HDD LED & Speakers cables on HP DX5150MT motherboard
look at motherboard it should had it inprinted on the board.
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
