Question about Exercise & Fitness
My fitbit does not show me any messages? - Exercise & Fitness
My Fitbit Charge2 will no longer synch with my iPhone. The Fitbit app on the iPhone shows that it is connected,
try completely shutting down the phone and the Fitbit and re-starting both after a couple minutes.
Also - make sure no other device with Bluetooth is on in the area.
Make sure the App is up to date too.
If no joy - contact Fitbit Customer support - they're pretty good with this kind of thing.
Jan 09, 2018 | Exercise & Fitness
My fitbit 2 charge is showing wrong time and date.how do I reset it
completely shut down the phone/device you sync with and the Fitbit. When re-starting, make sure there are no other devices that are trying to connect to the Fitbit, and that the app on the device you're syncing with is up to date.
this usually works. If not - contact Fitbit Customer Support.
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
Jan 21, 2016 | Exercise & Fitness
How do I delete messages from my Fibit Flex ?
http://help.fitbit.com/articles/en_US/Help_article/Can-I-delete-data
This article should help guide you in deleting data from your fitbit.
If you're trying to delete text messages, you should deactivate messages/notifications. You can find steps here
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-use-call-and-text-notifications-with-my-Surge
Jul 09, 2015 | Fitbit Flex Wireless Activity & Sleep...
My battery is charged but showing empty on computer. I restarted it but still showing empty.
with computer turned off take out battery and wipe off contacts then reinstall battery. If it is still empty after letting it sit a bit to see if it is charging you either have a bad battery or the charger in the computer is bad . that is an expensive fix. usually not worth the money unless you have an expensive computer and then that probably would not happen.
May 07, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do i get the caller id to appear on my fitbit hr. bluetooth is on and it says on my phone that it is connected, but it is not showing?
1. Have you installed the Fitbit app on your phone?
2. Have you checked to see if your phone is on the supported device list? If not, please check this link on Fitbit.com that will let you find out if your device is officially supported:
https://www.fitbit.com/devices#i.1eq9tls7t9eko1
3. If the answer is yes to both of these questions (as in yes you have the Fitbit app installed and yes your phone is officially supported), then I recommend removing your Fitbit from Bluetooth devices, and set it up again via the Fitbit application.
Feb 26, 2015 | Fitbit Charge HR Heart Rate and Activity...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
