My Frigidaire fmv156dsb microwave isn't working right... let's see it is an over the range, the lights work, and when you start it nothing happens, but it counts down though. I have changed the fuse and I am not sure what else to do with it... someone help me please?
That would be a bad primary interlock (bottom door switch) or its mount may be, loose, cracked, or misaligned.
We have
the service / repair manual for this model and have uploaded
it to our
site here for free download to help you.
It will
give you safety info, step by step help in disassembly, troubleshooting
tips, and part numbers.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
heatman101
