SOURCE: Won't crank, relay good.
Fuse would be in the outside fuse box. Look for the one labeled starter. If you are not getting power to the starter, could be an ignition switch.
SOURCE: Yard man cuts off with PTO enganged and tractor in reverse
when you put the machine in reverse it engages a safety switch, the switch can be jumped out with a piece of elec. wire, or it can be removed and repositened where it will not come into contact with shifter
Testimonial: "I'm unfamiliar with machinery, a little more detail would have been nice. Overall, this was right on the money! The solution was extremely helpful!"
SOURCE: no reverse lights on 2000 grand am or shift out of park lock
try disconnecting the plug off the reverse light switch (on the transmission) and bridging out the 2 terminals and then see if your revers lights work if they do replace the switch
SOURCE: Cub Cadet Model LT1042 (2007) The reverse mode
Nearly all lawn tractors on the market are designed to kick the cutting deck out of drive when reverse is engauged.
This is controlled by a simple electronic microswitch which can be disconnected but I would advise to leave it as it is ;)
SOURCE: Reverse override button doesn't seem to change anything
The override button on your Yamaha isn't supposed to override reverse. It will only disengage the rev limiter while moving forward when you have the "Diff Lock" engaged. When this happens, you will see your speedometer change to zeros. If you want to override your reverse, you will need to rewire a few things. I found the info I needed at "grizzhopper.com" to rewire mine.
