SOURCE: I am using an HP
I have a 4510s and had this problem before.
Part of the problem was synaptics driver was freezing, Driver
Synaptics software upgrade may help if that is part of your problem.
Have you opened the notebook to upgrade or remove the HDD for any reason?
If so, you should make sure the plastic of the palmrest (which houses
the touchpad mouse) has been correctly fitted back in place. It may also
help to remove the palmrest and ensure the flexible cable is correctly
inserted in the ZIF connector.
I also notice there are some contact points from the PC to the underside
of the trackpad, it may pay to clean those with metho to make sure the
electrical connection is good.
SOURCE: How do I unlock mousepad (touch pad) of hp
Just press: FN + F6 please vote for me... thanks .
SOURCE: in november i purchased an
Click Start
Click Control Panel
Click Mouse
Change the setting to disable the touch-pad.
SOURCE: how to unlock touch pad
I using Synaptics.......Go to Start, Control Panel, Mouse. Select Device Settings and then Settings. All required options will be there. If no Synaptics then go to the HP web and enter your model of computer and OS , then to software and driver downloads. There you will find the software and drivers required to give full functionality of the touchpad features. If not found there go to Synaptics web site and look for drivers and utilities for your OS version.
HP Link:
http://www8.hp.com/us/en/support-drivers.html
Synaptics Link:
http://www.synaptics.com/solutions/products/touchpad
Hope this helps
SOURCE: turn off touch pad on hp probook 6550b
http://www.retrevo.com/support/HP-6550b-Laptops-manual/id/23720dj691/t/2/
This is the users guide for your model. John
