Question about FoodSaver Kitchen Appliances - Others
The "moist" setting on my foodsaver only worked once, then never worked again. How can I fix it so it works? I bought this model specifically for this option.
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Food saver is stuck shut
I experienced the same problem today. I forgot to reinstall the drip tray prior after cleaning it. I closed the Foodsaver back up and it got stuck in the closed position and would not open no matter how hard I tried. I would push the green tabs and attempt to rotate it as per the instructions and it still would not open. I was able to resolve the issue by taking a flat head screw driver and carefully prying a few inches in from the sides of the machine. More specifically, the drip tray is basically a rectangle catch basis with two half circles on either end. Place the screw driver at the location of the half circles and gently pry at the parting line where you would normally put the bags while pushing both the green tabs. Once the tray is reinstalled it should work fine. If your like me, you wont make this mistake again. Good luck!
Jun 11, 2012 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver tilia v3240 manual
There does not seem to be a manual specific to this model. There is an extensive description of the product available on Amazon.com including a demo video.
See here:
http://www.amazon.com/FoodSaver-V3240-Vertical-Vacuum-Sealer/dp/B003U738ZE
You may also find one of the manuals from the 3000 series to be helpful. These and FAQs are available here:
http://www.foodsaver.com/manuals.aspx?cid=1177
Trust this is helpful.
Apr 16, 2012 | Tilia FoodSaver V3240 verticle vacuum food...
I wish to install a new vacuum pump and a heat ribbon in my Foodsaver V 2240. Please tell me how I can acquire these parts. My food saver has worked well for years but I cannot afford to replace it and...
Hi ipreinecke...
Go to the following website and you can purchase spare parts there for your foodsaver.
Note: Once you are on the webpage, mouse over the "Support" tab for parts and a user manual,etc.
Please take time to rate me thumbs up
http://www.foodsaver.com/faqs.aspx?fgid=17
Sep 11, 2011 | Tilia FoodSaver V2240
I am on my 2nd foodsaver. My 1st one stopped working, which I later found out, was probably due to the bottom gasket. My 2nd one had the same problem. I called FoodSaver, and they suggested that I flip...
I replace my gasket with a piece of 3/8" Poly Foam Caulk Saver (found mine at Home Depot - @$2.00 for 20'). It's a snug fit in the gasket groove. Cut long enough so that the ends touch tightly. It will create a good air seal and works well.
Feb 14, 2011 | Tilia FoodSaver VAC420
Sir, i have bajaj pulser 150, i bought in 2007.
Under the clocks are a set of wires. Make sure they are all in place. It sounds like there is a loose connection but once you're moving it fixes itself.
Make sure the earth wires from the battery are secure, a loose or rusty earth wire can cause electrical annoyances.
Hope this helps and vote if you are happy with it.
Jun 24, 2010 | 2005 Bajaj Pulsar 150
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver V2440 won't vacuum air out
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers foodsaver-v2440-vacuum-air-out-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 07, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
32 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
lucboisseau5
Level 1 Expert
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
