SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
SOURCE: Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
SOURCE: SONY TV KF-E50A10 NOT SWITCHING ON RED LED BLINKING 5 TIMES
Its the driver board ( Ballast ) you can get a rplacement at the following link
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
They also have the lamp with cage assembly at this link.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-lamp-assembly-with-cage/cName/sony-parts
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
SOURCE: copier gets ready, E000530-0000 is coming back again
error code e000530-000 moder ir3300 canon
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
