Here is HP's take on what you should try first.
https://h30434.www3.hp.com/t5/LaserJet-Printing/Color-Laserjet-Pro-MFP-M176n-Stuck-on-initializing-Toner/td-p/5572819
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
SOURCE: HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
SOURCE: HP Color LaserJet CM2320nf MFP Envelope wrinkles
trust me on this: ALL laser jet printers wrinkle envelopes; buy a cheap ink jet printer for envelopes
