Question about Health & Beauty
My left thumb and toe feel numb on the tip, what is that from and the problem
    Top Expert:
  • 5,110 Answers
SOURCE:
I have a numb feeling in my little finger on left hand what would cause this
for medical advise go to your doctor --fixya cant give you a medical exam to determine one of many reasons for your symptmon
Apr 23, 2017 | Cars & Trucks
My right hand, fingers ,and arm, tends to feel tingling an d numb feeling if i am on my left side
Always seek heath information from your doctor.
However, it sounds like a pinched nerve to me.
Mar 21, 2017 | Cars & Trucks
ZX4. Why does it swerve to the left?
have alignment rechecked the toe in or toe out might be off
Aug 28, 2015 | 2005 Ford Focus
Front Wheel Allignment
On these LH body cars, camber is not adjustable. Neither is caster. Those angles are preset by the suspension geometry. However, specifications for them ARE published. Generally, if either of those two parameters are out of spec, then it's likely something is worn or damaged and needs to be replaced.
The only adjustable parameters are to the front and rear toe but specified as "Total Toe" - see note below.
The alignment specs are as follows ...
ALIGNMENT SPECIFICATIONS AT VEHICLE CURB HEIGHT
A. FRONT WHEELS
  1. CAMBER
    Acceptable -0.6° to +0.6°
    Preferred +0.0°
    Side to Side Differential
    Acceptable 0.7° or less
    Preferred 0.0°
  2. TOTAL TOE - Specified in degrees. See Note Below
    Acceptable 0.4° in -to- 0.0° out
    Preferred 0.2° in
  3. CASTER* (reference angle)
    Acceptable +2.0° -to- +4.0°
    Preferred +3.0°
    *Side to Side Caster Difference not to exceed
    Acceptable 1.0° or less
    Preferred 0.0°
B. REAR WHEELS
  1. CAMBER
    Acceptable -0.6° -to- +0.4°
    Preferred +0.1°
  2. TOTAL TOE** - Specified in degrees. See Note Below.
    Acceptable 0.2° out -to- 0.4° in
    Preferred -0.1° in
    **TOE OUT when backed onto alignment rack is TOE IN when driving.
  3. THRUST ANGLE
    Acceptable -0.15° -to- +0.15°
Note: "Total Toe" is the arithmetic sum of the left and right Toe settings. Positive is Toe-in. Negative is Toe-out. Total Toe must be equally split between left and right wheels. Left and Right Toe must be equal to within 0.02° (2 one hundredths of a degree).
Courtesy RJK & Concorde Shop Manual
Mar 08, 2014 | 1994 Chrysler Concorde
How to adjust toe in
It is not advisable to adjust toe in without specialist measuring equipment, Set it wrong and the steering may pull to one side or the other and feel all wrong to the driver. It will cause excessive wear to the tyres, halving there legal life. Adjusting the tracking (Toe) is by screwing the tie rod ends in or out. See diagramdac7c2db-c651-41c7-b0e1-24dd4a16302b.gif
Jan 01, 2014 | 2005 Ford Excursion 4x4
What is the toe adjustment for a 1998 ford windstar 3.8L
Hello Snsimpson
Here are all the specs for the Windstar.
FRONT ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal -0.25°
Minimum -0.75°
Maximum +0.25°
Split 0.0°±0.5° Caster
Right
Nominal +3.80°
Minimum +3.05°
Maximum +4.55°
Split -0.5°±0.5° Left
Nominal +3.30°
Minimum +2.55°
Maximum +4.05°
Split -0.5°±0.5° Total Toe [1]
Nominal -0.10°
Minimum -0.40°
Maximum +0.20° Clear Vision [2]
Nominal -0.2°
Minimum -2.8°
Maximum 3.2° REAR ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal 0.0°
Minimum -0.3°
Maximum +0.3° Total Toe [1]
Nominal -0.06°
Minimum -0.40°
Maximum +0.28° [1] Positive value specifications for toe-in, negative value specification for toe is toe-out. [2] Negative value specification for clear vision is counterclockwise.
Nov 16, 2010 | 1998 Ford Windstar
Where is the fan blower resistor located on a 2002 Mercury Sable?
The blower motor resistor is mounted right next to the blower motor. the blower is above the passengers right toes and the resistor is above there left toes
Mar 17, 2010 | 2002 Mercury Sable
Wheel alingment specs for toyota land cruiser
Camber
Left−right error
1°00’ ± 45'
Caster
Left−right error
3°00’ ± 1°
Steering axis inclination 13°00’ ± 45’
Camber, caster and steering axis inclination are not adjustable.
If measurements are not within the specification, inspect the
suspension parts for damaged and/or worn out parts and replace
them as necessary.
INSPECT TOE−IN
Toe−in
(0.08 ± 0.08 in.
This is the only Land Cruiser Specs I could find, hope it helps
Apr 09, 2009 | 1996 Toyota Land Cruiser
Driver side toe-in
this would be your camber setting not the toe in. you can adjust the camber by removing shims from upper control arm but this will also affect other angles. best to just have it aligned
Oct 22, 2008 | 1998 Oldsmobile Bravada
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
