I have a mattle woody doll but its in french and i need to switch the language to english
SOURCE: changing from french language to english lauguage
You need to reflash ROM. Operation is a bit risky, if you don't follow the procedure. Consider upgrade to WM5/WM6.
All the information is on the below Link -
http://wiki.xda-developers.com/index...=HTC_Blueangel
Remeber about fixing you keyboard layout in registry
Good Luck
Thanks
SOURCE: Acer Aspire 7530, keyboard language switches
go to control panel
Then regional language option
then set english united states. then apply and ok.
If you not ablwe to read french then just set english it is upperr from current selection 5 or 6 check it.
SOURCE: How to change the i900 language from French to English?
HI, what you need to do is to go to settings on your phone...visit your phone setting and select language settings, select English Language.
cheers.
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
