SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
SOURCE: pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
SOURCE: how do i change the code in my kwikset 909 keyless
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
SOURCE: WHERE CAN i FIND A MANUAL FOR MY kWIKSET SIGNATURE
I think this is what your looking for... click link below.
http://www.kwikset.com/smartseries/smartcode.aspx
click on the correct link to your system at the bottom of the page when you get there.
Best,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Also, the inside light no longer flashes. The one that blinks either orange or green.
