I know the problem and the solution I use is to creep up very quietly and surprise it with a large air powered impact wrench. The prescribed method is to remove the starter motor and lock the flywheel with either the correct service tool or a suitable lever wielded by an assistant. Cars with a manual transmission are often easier - select top gear and apply the footbrake...
SOURCE: 2003 lancer replace serpentine belt
this pulley is still being hold by another bolt. it is a long one that is horizontal and can be access by a deep long socket wrench from the radiator side.
i hope you can find it.
tnx 4 using fixya,
drcool
SOURCE: power steering pulley keeps loosening on it's own
I"ve installed a number those p/s pulley . You need to check diameter of pump shaft, it sound like smaller the spec. Also when install those pulley you must lube the shaft or you score it.
SOURCE: which way do you turn the crankshaft pulley bolt to loosen it?
It turns left (counterclockwise) to remove. An impact wrench is best if you can get one on it.
If you don't use an impact wrench, you may need to somehow keep the crank from turning when you loosen the bolt.
One way is to pull the belt tighter to put more tension on the crank pulley.
There are other creative ways I've used. If you have any trouble let me know.
SOURCE: Upon accelerating, there is a chirping sound
the chirping noise you hear are the belts being loose,adjust the tension on the belts,if the pulley bolt has not loosened up by now ,you dont have a bolt problem-when you have the timing belt replaced ,have the mechanic put some lock-tite on the bolt
Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
Follow the serpentine (outer) belt to the three pulleys lined up vertically near the front of the engine compartment. Locate the middle pulley, which is the tension pulley for the belt.
Loosen the bolt on the middle pulley with a socket wrench by turning counter-clockwise. Do not remove the bolt, just turn it a couple of times. Loosen the tensioner bolt on the side of the of the pulley, facing the front of the vehicle.
Remove the serpentine belt and then loosen the bolt on the alternator. With the alternator loose, move it forward so that the alternator belt loosens up and then remove belt from the pulleys.
Install the new alternator belt by placing it over both inside pulleys. Tighten the tension on the alternator belt by moving the alternator back and keeping tension on it by holding it back with a long screwdriver. While the alternator belt is tight, use a socket wrench to tighten up the bolt on the alternator.
Place the serpentine belt back on the pulleys and then use a socket wrench on the bolt on the front of the tension pulley. Once the serpentine belt is tight, tighten up the bolt in the middle of the tension pulley.
Start the Mitsubishi Lancer's engine to test the alternator belt and make sure it is working properly. Once you have verified it is working, turn the engine off.
