SOURCE: have a fisher and paykel
Hi - A 703? quite an oldie - 132 is basically a comm error between the electronics & the drive system on the motor - if you wish to toto with it - be sure the plug is removed from the wall socket -
Tools required - Multimeter - a 5/8 socket - a 3/8 socket to remove the motor system.
After disconnecting the power & hoses etc - tilt on its back - take 5/8 and remove the rotor in the center is a plastic nut - remove and keep it away from metal surfaces its magnetic - take the 4 bolts off - carefully remove the stator (copper windings) on topside are terminals - make careful note as to where the wires came off - carefully place on a towel not to be damaged - check the terminals for corrosion etc - see if the wires are okay - breaks in it best use the multi to check for continuity - check the point where the harness connects to the small electronic (RPS) board for corrosion etc - lastly is the RPS in good nick?.
These are the symptoms for the error code you requested --
Nice weekend to you & have fun....
